How to repair my shifter
My truck won't go into any gear unless i use the shift lock release button
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
khalif, I think you should combine the two of the questions you are asking. I think there might just be a common connection. I would start with replacing the brake light switch. As you mentioned in your other question, your brake lights do not come on when depressed. If your brake light switch is malfunctioning, your brake lights will not work,nor will your gear shift locking mechanism. Check the wiring on the switch, makes sure it is adjusted right, and you can check it with a multimeter.Replace the switch, re-evaluate and let us know. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
I replaced the brake light switch in my buddy's crv 2001 and still no brake lights? There on but don't Britten up when peddle is pressed no high mount light on though and replaced all bulbs and checked all fuses
Did you check the switch to make sure that it is being activated when the pedal is depressed?
Ya there is a white pin that pops out when peddle is pressed I replaced it and still nothing
Replaced the switch sorry made it sound like I replaced the white pin the way I wrote that
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,240
