Ana içeriğe geç
Chromebook Pixel'in manevi halefi olan Google Pixelbook, 2017 Made by Google etkinliğinde tanıtılmış ve 31 Ekim 2017 tarihinde satışa sunulmuştur. Model numarası: C0A.
How to repair Pixelbook wireless
Google says it's outside the warranty period and it's a wireless hardware issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @sabinagmail
What is the problem with the WiFi?
If it is turning on but not connecting to a network, then it may be an antenna problem, loose or disconnected perhaps. Try using the laptop as close as possible to the network router e.g. <10cm, and check if the WiFi works OK.
If it does, here's the ifixit Google Pixelbook anakart değişimi guide. At Step.24, the antennas can be seen being disconnected from the WiFi card.
If there are other problems with the WiFi and you've proven that it is a hardware problem and not a software problem (powerwash?), the WiFi module (Intel 7265D2G) is soldered onto the motherboard so it won't be easy to remove.
Searching online for a replacement WiFi card produced no results.
Unfortunately I was also unable to find any USB-C WiFi dongles that you could use to connect to the laptop so that you could have WiFi capability again.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you! Will try it.
tarafından
Yorum Ekle
Yanıtını ekle
Sabina sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 650
