Fault Code 02 - Vent Axia
Hi the fan is not working (left hand side as you look that sits behind white grill).
Is this easy to repair / replace? Spins easily enough with slight touch so wonder if electrical issue?
Any advice?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
@byronb12 have you checked for power on the fan with a meter? Fault code 2 is the code for the Right Fan. Post a couple of pictures with your QUESTION, that way we can see what you see and hopefully find a solution. Mevcut bir soruya görsel ekleme
tarafından Paylaş
Yorum Ekle
