Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
SATA SSD running faster than SATA2 but much slower than SATA3
I recently changed the HDD to SSD. The SSD is KIOXIA TC10 which has read/write speed over 500 mbps. However, the speed accessed by Blackmagic disk speed test is Read 400mbps/ Write 200mbps.
I know some early product of A1278 has a thin SATA2 cable which may not support SATA3 speed. However, SATA2 is at most 300mbps. The current SSD can run read speed at 400mbps which is faster than the limit of SATA2. It seems like the current cable is SATA3.
I don't know if I need to replace a cable or to replace the SSD.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What is the drives format GUID/Journaled (HFS+) or GUID/APFS try APFS
Your performance is what I would expect based on my testing with a Samsung SSD.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
It is on GUID/APFS. Queue depth 32. TRIM enabled. Two volumes on the disk.
EFI: 209.7MB MS-DOS FAT32 disk0s1
disk0s2: 239.85GB disk0s2 Apple_APFS
tarafından
Yorum Ekle
So the problem is on the SSD. The KIOXIA TC10 doesn't have DRAM and so the speed can fluctuate drastically. I replaced another Samsung 860 EVO SATA SSD which has 512 MB DRAM. Now the speed can goes up to 550/520 Mbps.
Turing on FileVault decreases the speed also. After turning on FileVault, the speed drops below 500.
Puan 0
Yorum Ekle
Yanıtını ekle
ken22 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
