Ana içeriğe geç
Samsung'un amiral gemisi telefonunun daha büyük versiyonu. Mart 2018'de piyasaya sürüldü.
Why does my phone keep restarting?
At first it only restarted a couple of seconds after the screen was off. I tried to fix it by trying to update my phone, restarting it manually, and deleting some apps. But now it just turns off randomly every couple of minutes. It just started today, u don't know what to do.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@gus_gush since it appears to become more frequent, you want to start off with a new battery. If nothing else it will provide you with a known-well starting point
Samsung Galaxy S9 Plus Batarya Değişimi
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi @gus_gush
Does it do this with the charger connected?
Things to try and see if they resolve the problem:
  • Wipe the cache partition and check if that resolves the problem.
  • Try starting the phone in safe mode and check if it works OK. If it does then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app one by one and then test the phone in normal mode between each uninstall to see if the phone works OK or not. When it does work OK then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and it wasn't pre-instaled on the phone when you first got it.
Puan 1
2 Yorum:
Its not doing it when my phone is on the charger
tarafından
@gus_gush
Then I suggest that the battery is replaced as recommended above by @oldturkey03
tarafından
Yorum Ekle
Yanıtını ekle
Gustavo A Reyna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,249
