My hp notebook not powering on
Hi everyone, my pc is hp notebok gaming series and is not powering on. My charger works just fine. So here's the scenario, I plugin my charger and the LED doesn't show power and I can't turn on my PC. However, when I plugin my external hard drive it shows power on its LED but still the AC adapter LED is dimmed and can’t power on. Help me out please!
Bu iyi bir soru mu?
4 Yorum
Hi,
Please verify the full model number of the laptop as shown on the info label on the bottom of the laptop.
Also how did you test the charger? Was its output 19.5V DC?
has the laptop been dropped or gotten wet at all?
Have you checked that the laptop is fully turned off by holding the power button operated >10 seconds? There should be no power on the USB ports if the laptop is off.
If the AC adapter is plugged in and the laptop is started but won't then power on the USB ports indicate that it has started to turn on but has stopped for some reason.
jayeff tarafından
This is the exact model. https://www.techadvisor.com/article/7168... @jayeff
Natnael Fisseha tarafından
My battery is dead so I have removed it and I'm just using the PC direct. This problem happened twice now. The first time, technician did replace the AC adapter with a new one and still had the same issue. The second time, I just didn't do anything and it started working again. And now the problem is persisting. I have figured out that power seems to be transmitting to the board because the USB is lighting my external hard drive. And of course since I am using the PC direct, it has completely shutdown when I unplug the AC.
Also it hasn't been dropped or got wet. However, my CMOS battery is detached from the board for some reason.
