Ana içeriğe geç
TI-30Xa bilimsel hesap makinesi için cihaz onarımı ve sorun giderme.
Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
tarafından
@notbroken oh ok thanks
tarafından
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Texas Instruments TI-30Xa Teardown guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
Papaya Bear sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 579
