Why does my ice maker and water dispenser work with filter removed but
Why does water dispenser and ice maker work when filter removed but doesn’t when filter installed
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @thomasmo
A lot of refrigerators have an automatic filter bypass mechanism in the filter housing (example only) which activates when the filter is removed so that water is still supplied to the ice maker and the water dispenser.
When a filter is inserted it should cause the bypass mechanism to switch the water supply back so that it now goes through the filter. Make sure that the filter is fully inserted and locked into place
It may be that the housing (incl. the bypass) is faulty. Here's a video that shows how to replace it.
What is the model number of the refrigerator? Knowing the model number of the refrigerator will ensure that you can find the correct one for your model.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 127
Her zaman: 2,166
