Monitor is off after lightning
Wanna fix the monitor that wrnnt off after over voltage
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
5 Yorum:
Can you disassemble the monitor, then upload pictures of the circuit boards? Mevcut bir soruya görsel ekleme
tarafından
jackmotimele104 are you saying that the monitor does not want to turn off? It is on all the time?
tarafından
Did you try another External Power Supply?
tarafından
I'm having the same issue with what looks like almost the same exact monitor: LG 27GL650F-B. Seems like a power surge happened even though I have a surge protector because the monitor flickered, then shut off, and hasn't been able to turn back on since. What tools do I need to fix this and does anyone know how?
tarafından
@ryanarther if anything it'll most likely be the power board. You will have to disassemble your monitor and check the board. As for tools, commonly just a few hand tools (screwdriver set) will do. You may need more once you know what is wrong with it, but for now, just disassemble and evaluate.
tarafından
Yorum Ekle
