Ana içeriğe geç
The Beats Studio3 was released in September 2017. There is no wired-only version of the Studio3 Wireless, however, it does include a 3.5 mm audio input port and a black RemoteTalk Cable for optional wired operation.
My whole right side speaker came off
My speaker came out off place and can’t get it back in
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
it is quite important which place you mention. Take a photo and share here.
tarafından
Hi
Do you mean that the swivel/balance has came off?
It would be amazing if you could add some photos:-)
Here’s a guide for that
Adding images to an existing question
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think you need to hook in the the metal clip first by sliding it back and forward until seated and then pop the rest of the outer rim clips back on.
Just be careful not to pinch or break the wires.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Had a similar issue just happen on my daughters pair of Beats today, managed to repair them. For prosperity and future Beats repairers, the "paddle" of metal in the left of the images needs to be slotted into the gap on the right. The two halves of the ear assembly are held in place with a screw that attached from the speaker to that metal plate. Whilst my problem was not exactly this (the screw had simply detached from the plate), to fix my problem, I did the following:
  • Remove adhesive earpad with a blunt spludger tool
  • Remove 2 x charge port Philips screws and 5 x speaker Philips screws (I used a 1.2mm driver)
  • Carefully separate the speaker from the earcup and remove the circular adhesive pad in the centre
  • The retaining screw for the paddle is under this circular adhesive pad and can now be removed and / or tightened as needed.
To fix the exact problem as above, the screw could be removed, the metal plate reinstalled and the screw re-inserted to reattach the two halves.
I had to purchase some special replacement adhesive pads to re-attach the earpads once again since the adhesive is toast once you pop the earpad off. Amazon,, was about £6 for two adhesive pads, you can get cheaper from AliExpress if you want to wait for shipping.
Hope this helps someone!
Puan 0
Yorum Ekle
Yanıtını ekle
Drwestcuts sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 433
