Blank Screen after replacing JoyCon
I replaced my Switch Lite's left JoyCon, but now the screen will not turn on. The fan spins up, and the speakers make noise when I press any buttons. How can I fix this?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Check the small ribbons about halfway up on the left of the board are seated properly. Below the card reader if I remember correctly. One is for the back light and if not inserted correctly causes a black screen.
Bu yanıt yardımcı oldu mu?
Both ribbon cables seem to be seated properly, they are in as far as they can go, the gold contact is facing up, and the fastener is secured.
check the ribbon connecting the daughter board to the motherboard, make sure on the daughter board side the gold contacts on the ribbon are facing up and not down
Both ribbons appear to be secured properly, with gold contacts facing up and inserted as far as they can go. I'm really stumped here
If you still have the original joycon, then you could try to put it back.
This would help rule out potential hardware issues with the new joycon, if you are 100% sure it's not a poor seat on a ribbon connector.
I would also inspect and unseat the screen ribbons and make sure they and the connector slots are clean.
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 45
Her zaman: 2,528
5 Yorum
what do you mean by replaced the joycon? the analog stick?
just some mango tarafından
did you mean you replaced the buttons? or did you choose the wrong device/modified the lite?
timtom77 tarafından
@sadmango Yes, I meant that I replaced the analog stick, sorry for the misunderstanding.
Aidan wheeler tarafından
@timtomissus I replaced the moving analog stick, as it was broken off.
Same problem but right side
EmersTheMoo03 tarafından
