Why is wifi not working
When i switch on wifi, it does not show available routers & it does not access any wifi connection
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if it detects the networks and connects to it.
If it does then it may be a loose antenna problem.
Here's an image of the phone taken from a teardown video that shows the antenna connections at both ends of the phone.
(click on image)
If it still doesn't work it may be a problem on the systemboard. Here's an image of the no BT/WiFi troubleshooting flowchart that may help.
(click on image)
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 452
2 Yorum
WiFi not work
=== Update (05/11/24) ===
Samsung A10 WiFi not work
Nauman rajput bhtti tarafından
