Whirlpool Gold WDF750SAYM unique issue
My issue is related to Whirlpool gold WDF750SAYM. A couple of weeks ago, the dishwasher would go through the complete cycle, however, when I opened the door and checked, the dishes were dirty and I could tell the water was not pumped or sprayed through the arms.
I reset the breaker and then tried a cycle and this time, the dishes were washed(water circulated) however, they were not dry and the drying cycle did not work. The next time, I noticed the dishes were washed and the heat cycle kicked in and then there was water at the bottom of the dishwasher and it did not drain.
To troubleshoot, I disconnected the dishwasher and tested the thermostat with a multimeter it had connectivity but I still replaced it since it had purchased it. There was also connectivity at the heating coil. I replaced the turbidity sensor as well.
After replacing the above parts, I ran a diagnostic cycle and it came back at 8-1 which appears to be drain pump related however when I push the cancel button, it immediately drains out the excess water from the dishwasher.
I then reset the breaker and ran the diagnostic cycle again and got the same error 8-1 however the complete diagnostic cycle ran and there was water circulating, heat, and then water was drained. I was unable to clear out the error codes and do not know how to clear out the codes.
This time I loaded the dishes again and the dishwasher filled with water but did not recirculate through the spray arms.
I ran another cycle however put it in sensor mode and the complete cycle ran this time however it took 7 hours.
I am so confused as to what the problem is. The pump motor is working, the drain pump is working, the heating coil is working, the thermostat is working, the turbidity sensor is new. The float switch also appears to be working. I am thinking this may be the control board issue.
Help please on the next steps or what the issue might be.
Thanks,
Bu iyi bir soru mu?
