Ana içeriğe geç
This guide is for the Lenovo Yoga 720-15IKB. Released in 2017, the Lenovo Yoga 720-15IKB is a 2-in-1 laptop with four distinctive orientations to use it in.
7 Soru Tümünü görüntüle
Laptop will not turn on.
My Lenovo YOGA 720-IKB will not turn on. The power button fades off and on to show that it is in standby, but it will not go any further than standby. If I touch the keyboard it turns all the way off.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Disconnect the battery as shown on step 4:
Battery
and just plug in charger. Any change?
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
No change at all.
tarafından
Found a new power supply, and it boots up, what is really interesting is that this power supply is the wrong amperage, whereas the original power supply is correct. I did test the power supply on another laptop and it worked on it. This laptop also refused to take a charge from a USB-C charger which is supposed to workl.
tarafından
Amperage is to do with the "stength" of the energy.
If it is not strong enough then internal electical components will be strained.
A bit higher amperage will just mean there is energy to spare.
So nothing unusual there. The original one may have been "just enough" and so had a shorter life.
tarafından
What is interesting is that this new power supply has less amperage, which is why it surprised me. Doesn't appear to be straining the system, but I'll probably be buying another of the correct voltage/amperage soon.
tarafından
Considering what you said it would seem that the power supply you had was faulty, maybe a bad capacitor which would allow to show on a multimeter to have the continuous correct voltage but once under a bigger load the cap heats up and the amperage and voltage drops. It is permissable to go as much as 3 volts above what's called for but no more than 3 volts.
tarafından
Yorum Ekle
Of course I cannot say for sure but sounds like the battery is dead. Some machines will preserve enough battery life to continue storing your installed programs. Sounds simple I know but...
Puan 2
1 Yorum:
That's what I figured, but it doesn't fix anything. No matter how long I charge it it won't boot. I know it's charging as it wouldn't turn on when I got it, and the power light by the power input lights up.
tarafından
Yorum Ekle
Check the power supply. One of the first things to check when your laptop is not turning on is the AC adapter (power cord). ...
Faulty screen.
Check for incompatible hardware.
Replace battery.
CMOS battery.
No bootable media error.
Windows crashes during startup.
Regards,
Will
Puan 1
1 Yorum:
I have checked everything but the CMOS battery (it doesn't have a removeable one) and the screen. I will work on that tonight, hopefully.
tarafından
Yorum Ekle
Well you can try:
  1. Unplug the power cable from your laptop.
  2. Locate and remove the battery.
  3. Press and hold the power button for 30 seconds.
  4. Re-insert the battery and plug in your laptop.
  5. Attempt a restart and cross your fingers.
Puan 0
Yorum Ekle
Yanıtını ekle
Killshot sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 66
Her zaman: 977
