Ana içeriğe geç
Laptop crashes while waking from sleep while on battery
Hi folks - I recently replaced my laptop battery on the hp spectre x360. Battery seems to do fine while the computer is up and running - steady orange light when it is charging, steady white light when it is full. However, when I boot from shutdown or wake from sleep, it shuts down and won't start up when on battery power - I need to be plugged in for that. It crashes just as it is waking up.
HP Hardware Diagnostics and Windows power diagnostics aren't turning up anything, and no updates to the firmware from what I can see in the device manager. At my wits end, any help would be much appreciated! Thanks!
Update (03/09/2023)
Here's the image of the battery report
Bu iyi bir soru mu?
Puan 1
2 Yorum
Exact issue I'm having with an Amazon replacement battery. 2020 x360 15-eb0053dx
tarafından
This is identical to what’s happening with my spectre, not long after update to windows 11, I also replaced my battery just after it started to happen.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey for whoever ends up on this thread - I ended up having to replace the battery again after it degraded again due to the fans not really cooling the laptop. It boots just fine from battery now so issue was the battery - the new one has the 1" square metal pad at each end that neither of the replacement batteries I had tried before had just like @trainguy mentioned. I had used something that claimed to be an OEM HP part last time and this time just got the cheapest thing off of amazon, YMMV.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Hi @aidanoneill ,
Just to check that the battery is OK create a battery report to check its status.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good, new battery they should nearly be the same.
If the report shows that it is OK try uninstalling the Microsoft ACPI-Compliant Control Method Battery driver in Device Manager, restart the laptop and let Windows reinstall it and check if that resolves the problem.
To get to Device Manager, press the Win key + x key (both together) and click on the Device Manager link that is in the options box that opens.
When in Device Manager scroll down to the Battery category, click on the > symbol to expand the list, right click on the Microsoft ACPI-Compliant Control Method Battery entry and click on Uninstall device and follow the prompts.
Then restart the laptop in the normal manner
Puan 3
10 Yorum:
Hey @jayeff - thanks for the quick reply, appreciate you. Design capacity and full charge capacity are identical on the report. Went ahead and reinstalled the driver via the device manager and laptop is still shutting down. Any other ideas?
tarafından
Went ahead and threw the full battery report in the original description
tarafından
@aidanoneill
Try turning off fast startup and see if that resolves the problem.
Press the Win Key and x key (both together) and click on the Power Options link
When in Settings > Power and Sleep, click on the Additional Power settings link on the right side of the page
When in Power Options window click on Choose what the power buttons do.
In the Power Options > System Settings window click on Change settings that are currently unavailable.
Uncheck Turn on Fast startup (recommended) and then click Save.
Close all the open windows and restart the laptop in the normal manner and check
tarafından
Tried! No luck still. On Win 11 if that matters at all
tarafından
@aidanoneill
Best I can think of is to uninstall the display adapter drivers in Device Manager restart the laptop and then let Windows reinstall them and check.
Go to Device Manager > Display adapter > right click on the display adapter entry and click on Uninstall device and follow the prompts.
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Aidan O'Neill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 659
