Ana içeriğe geç
Honda Fit, diğer adıyla Honda Jazz, 2001 yılından beri üretilen ve şu anda üçüncü nesli yollarda olan, beş kapılı, önden motorlu, önden çekişli B segmenti bir alt kompakt otomobildir. Dünya genelinde pazarlanan ve sekiz ülkede on farklı fabrikada üretilen modelin satışları 2013 yılı ortası itibarıyla 5 milyona yaklaşmıştır.
2012 Honda Fit - Engine Compartment Fuse Box
Does any other year and / or model Honda share a identical Engine Compartment Fuse Box with my 2012 Honda Fit? Mine has 3 fuses, a 100 A for Battery, a 70 A for EPS, and a 20 A for Horn/Hazard (turn signals). The 20A fuse is blown, I can't see any way to replace just that fuse. I don't want to cobble up a blade fuse, so my only choice is to replace the entire box. I'm retired, so I don't want to pay the dealer price, so you see that means u-pull-it, the reason for my question.
Can anyone help me out, please?
Thank you for any help,
Jim K
Resim
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @jimknowles
Have you checked if fuses 23 & 24 in the under dash fuse block are OK and are the correct rating, as they are fed by the blown 20A fuse that you want to replace?
They are both 10A fuses so by rights if there was a problem with the hazard lights (#23) or the stop lights/horn (#24), they should have blown and protected the fuse in the battery fuse block before it blew.
Don't know about how to remove it, but according to the 2012 Honda Fit service manual the fuses are not serviceable - see image below.
Resim
(click on image)
Try searching for 38210-TK6-003 and see if you can find one for a better price than what the dealer is asking.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Jim Knowles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 1,428
