Ana içeriğe geç
JVC KW-M650BT, 6,2 inç net dirençli dokunmatik ekrana sahip bir dijital medya alıcısıdır.
AV Input is glitchy
Background: I am trying to hook up a nintendo 64 for the head unit. So far I can get a picture but it will constantly float up and reset. Ive tried different rca cables to no success.
Do you know of any way to not have the picture float away and be glitchy.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
@ricardocapriles Do you have a PAL or NTSC Nintendo 64?
tarafından
NTSC n64
-ricky
tarafından
@ricardocapriles Have you tried using another composite device like an SNES/NES or old camcorder?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The issue may not be with the cables, it may be ports on either the Nintendo 64, or on your media receiver unit. You may want to check the connections to make sure they are clean and don't have any dust or corrosion on them. If there is no problem with the connections, it is probably just something wrong with the video output circuitry in the Nintendo. In that case if you do have the technical knowledge you may be able to open the device up and attempt to replace any faulty components.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ricardo Capriles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 394
