Ana içeriğe geç
Tahoe Limited Edition haricinde bu araç, tam boy kamyonetler ve SUV'larla ortak olan yeni GMT800 platformu üzerinde 2000 model yılı için yeniden tasarlandı.
Having a problem turning it on
I recently had my Denali stolen and the thieves manage to mess up my whole ignition really badly … now my key don’t fully turn all the way and the only way to turn it on is by hitting a relay on the fuse box is there any solution to my problem …?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Most likely one of three possibilities. Attached to the actually key switch are two small usually light green switches, one may have gotten broken moved etc during the theft.
2: that particular relay has sticky contactors inside and needs to be replaced.
3: inside the steering colum cover at the ignition switch and gear shifter there is a stop the prevents the key from being turned to the run position if the shifter is not completely in the park position. I could have gotten bent or mis aligned during the theft.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
El gallo chingon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 405
