Ana içeriğe geç
Is there a fuse there?
Where is located the fuse and how can I approach it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
There are numerous fuses. Can you describe the symptoms?
tarafından
The printer does not show any sign of life after an unclear power interruption.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try the following methods to restore power to the Brother machine:
3.1 Method 1
  1. Remove the power cord for at least 30 seconds.
  2. Press and hold the ON/OFF button down, and then insert the power cord back into the machine.
  3. Do not release the ON/OFF button until the machine has been powered on completely or after 15 seconds.
  4. Repeat this procedure up to three times if necessary.
3.2 method 2
  2. Remove the paper tray from the machine.
  3. Reconnect the power cord, and then power the machine on.
  4. When the machine has been powered on completely, insert the paper tray back into the machine.
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
tarafından
Yorum Ekle
Yanıtını ekle
tvarozna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 559
