Is there a fuse there?
Where is located the fuse and how can I approach it?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
Bu yanıt yardımcı oldu mu?
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 563
There are numerous fuses. Can you describe the symptoms?
Jim tarafından
The printer does not show any sign of life after an unclear power interruption.
tvarozna tarafından
