Toshiba 50INCH 50UL2163DBC TV, no picture with white burn mark
I’ve just got back from visiting my boyfriend and the TV that I purchased in November 2021 has absolutely no image whatsoever, but it does after a short wait have a blueish white burn mark that just gets bigger and bigger until it fills most of the screen. I’ve got sound so I know the TV is working but the screen isn’t and I’ve really not had it very long, or moved it around at all. It was working on Tuesday with no issues when I was last at home, have tried power cycling too.
Bu iyi bir soru mu?
Puan
0
@idkx6qkcc57valj post some pictures of what your screen shows. The way we can see what you see and hopefully give you a helpful answer Adding images to an existing question
oldturkey03 tarafından
[image|2895640][image|2895639] sorry I had uploaded these images but didn’t realise you then needed to add them again
hannahwheatley1000 tarafından
@idkx6qkcc57valj try other input sources. Check HDMI, Component and even regular cable coax. See if that changes anything when you select different input sources.
