Pitchure gone on my tv
What it is is my screen gone pic not coming up but it still got sound
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@robertconnolly first you need to verify that you have no image on all inputs.Try all the inputs on your TV. Change your HDMI cable as well. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a channel where you can hear the sound See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that, so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 110
