Ana içeriğe geç
How do you replace the screen?
I am looking to replace the screen on my Lenovo G700, how can I go about doing this myself easily?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @kingz77048
Here's the hardware maintenance manual for the laptop.
Go to p.57 to view the procedure to remove/replace the LCD panel.
On p.74 Item #2 there are the part numbers for the 4 LCD panels compatible with the laptop. Usually the part number can be found on the back of the panel, if you wish to get the exact same replacement panel.
Search online using the appropriate part number only to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Ordering the screen, carefully removing the old one while noticing where everything goes, so you can easily get it back after.
Puan 0
Yorum Ekle
Replacing a laptop screen can seem daunting, but with some preparation and patience, it can be done. Here are the general steps you can take to replace the screen on your Lenovo G700:
  1. Purchase a compatible replacement screen: You'll need to find a replacement screen that is compatible with your Lenovo G700. You can typically find replacement screens online through websites such as Amazon, eBay, or specialized laptop parts stores. Make sure to find a screen that is compatible with your aptop model and screen size.
  2. Gather the necessary tools: You'll need a few tools to replace the screen, including a screwdriver set, a plastic pry tool, and an anti-static wristband.
  3. Power down and disconnect your laptop: Before you start the repair, make sure your laptop is powered off and unplugged from the wall. You should also disconnect the battery if possible.
These are the general steps you can take to replace the screen on your Lenovo G700. Keep in mind that specific models and brands may have slight variations in the process, so it's always a good idea to consult the manufacturer's instructions or seek professional assistance if you're unsure about anything.
Puan -1
Yorum Ekle
Yanıtını ekle
Kingz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 389
