Ana içeriğe geç
2018'den 1000 watt toplam güce sahip 5.1 Ev Sinema Sistemi. Blu-ray oynatıcı, dahili Wi-Fi ve kolay müzik ve video akışı için Bluetooth bağlantısı içerir.
Micom Options are lost
My hometheater not working properly. I figure out micom Options are lost. All the op0, op1.. to op5 are 00. Is there anyone who has these codings. Of you have the device you can see the options through (NO DISC or Tray OPEN State) and Setup-DISPLAY-TV Aspect Ratio16:9 Full 4+5+6+2 +5+8+0 +ENTER
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @sercantaylan
Have you tried a power refresh?
Turn off the home theatre if it is on, disconnect the power to the home theatre and then press and hold the Power button for a full 30 seconds and then release it. Reconnect the power to the device, turn it on and check the settings
If no good, try contacting the LG customer service centre in your location (ask for tech support) and ask if the latest software version is available for your model home theatre, either as a download link or an emailed file
If they state that you can update online using the settings in the device (Settings > Others> Software > Update) tell them that there are no settings available and that you can't do this.
Also if there is software available ask how to install it manually.
Just what I'd try
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I have updated but no change. I think the update doesn't make any change on eeprom :(
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Sercan Taylan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 368
