Ana içeriğe geç
Repair and troubleshooting information for 14 inch HP Pavilion laptop computers with model numbers starting with 14-ab.
2 Soru Tümünü görüntüle
My laptop is just lighting the power light but no display or keyboard
My laptop is just lighting the power light but no display or keyboard is lighting
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @markoesibz
Try a power refresh and check if that resolves the problem.
  • Disconnect the charger from the laptop and then remove the battery from the laptop. Here's an image that shows how if you don't know.
(click on image)
  • Press and hold the laptop's Power button for a full 30 seconds and then release it.
  • Reinsert the battery, reconnect the charger, turn on the laptop and check if it starts OK.
If it starts OK then there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected the message won't appear the next time that the laptop is started.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Well for Keyboard backlighting issues can be caused by a range of factors, one of them being the driver not being updated. Keep your drivers updated to avoid this issue. And there is no display, then that means that the system is getting powered up, but the GPU might having problems, your internal disk drive is corrupted or damaged, your display is damaged, or LVDS cable might be loose.
Puan 1
Yorum Ekle
Yanıtını ekle
Markoe Sibz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 73
