Ana içeriğe geç
Laptop not turning on
Strix g15 ryzen 7 4800h and GTX 1650 ti
The laptop is not turning on , the power indicator does not light up even if charging . The laptop flashes the power light for a brief second at the moment the power is connected and goes dim again ...
Sometime i just let it sit for 4-6 hrs and it generally starts to work again , the laptop is currently not turning on
I have tried unpluging the laptop and holding the power button for a minute or two , and when i connect the charger and try to start it the power light just flashes and the laptop does not turn on .. please help
I have also tried the hard reset when the battery is removed ...
I have look at the forum for any possibile solution .. i have also replaced the motherboard but the same problem persists ...
Any suggestion pls
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum
did you check your work on the motherboard? you may have left connectors off of the board or ripped them
tarafından
I have also the same problem, if your problem get fixed plz can you help me
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try a different charger o r charger cable
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Rashid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 687
