Ana içeriğe geç
The Samsung Galaxy Tab E 8.0, a touch screen tablet made by Samsung Electronics, was released in January 2016. This page includes repair information for model number SM-T377V.
Tablet screen is very dim
Hello! I need a bit of help trying to fix my tablet. I dropped it on it's side earlier, and now the screen's brightness seems to be very low. The device is still working well, I can use it like I would everyday. But the screen is super dim, almost impossible to see in the light and dark rooms.
I assume this may be an issue with the backlight. Is there any way to fix this? :[
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@kayjayy not really. Other than opening it and making sure that all the ribbon cables are still connected and no components have been dislodged. Looks like you might be due for a new display but check it first for the aforementioned. Samsung Galaxy Tab E 8.0 Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
thank you! I will try this when I get home! Is there a guide tp help with the first thing mentioned (making sure ribbons are still connected)?
tarafından
@kayjayy first step same guide. Once the back panel is off, you should see all of the ribbon cables. Check those carefully for nicks, tears and improper seating.
tarafından
Yorum Ekle
Check the proximity sensorClick to Expand
Deactivate Adaptive brightnessClick to Expand
Increase the Screen timeoutClick to Expand
Keep the screen active while you are using itClick to Expand
Change the Secure lock settingsClick to Expand
Change the power saving mode
Regards,
Diana
Puan 0
Yorum Ekle
Yanıtını ekle
Kayla! sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 1,211
