Ana içeriğe geç
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Right Hinge Damage, hinge replacement or shell replacement?
I’ve been going through some boxes and found my original 3DS XL in a bit of a sorry state, everything is fully functional, all the buttons work, it reads games fine, it charges 3D works, and both screens do, however the right Hinge has snapped off from the console, I am wondering if I need to do a full shell replacement, a hinge replacement, or if could just superglue the broken piece back onto the console
I believe the box that the console was in was dropped whilst I was moving.
Any help will be appreciated :)
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@anacecase superglue is out ;-) It won't hold for very long based on the movement of the hinges etc. I would go with a shell replacement. Little bit more work but that way everything aligns properly and should not give you any trouble in the long run. iFixit does have the guides needed for more of the wok right here 3DS XL Repair - iFixit
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi, would there be an option to order just the casing of the right hinge, I managed to get the broken one back on put due to its damage it came off again, I feel that a complete one of these will fix it
tarafından
@anacecase I have not seen them offered like that, so I am sorry but I can not tell you.
tarafından
The part that's broken off is molded to the top case so it's not going to be available separately. You can buy just the top of the case on Amazon for about $10 USD that will fix your problem.
https://www.amazon.com/Replacement-Housi...
tarafından
Yorum Ekle
Yanıtını ekle
AnAceCase sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 117
Her zaman: 2,723
