Ana içeriğe geç
İlk olarak 2019'da piyasaya sürülen, buz yapıcı veya kapı üzerinden su/buz dağıtıcısı bulunmayan otomatik buz çözme sistemine sahip GE Buzdolabı GFE26JGM**** için onarım ve ek bilgiler. Bu sayfa, GFE26JGM**** desenine uyan model numaraları için bilgileri kapsar.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Resim
Resim
Update (05/05/23)
  • trying again
Resim
Resim
Update (05/05/23)
GFE26JGMWFBB is the model
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
can you add photos
tarafından Paylaş
@dougwilds i can't see them doug it just says image
tarafından Paylaş
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Doug Wilds sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 645
