Ana içeriğe geç
Aynı isimli sosyal girişim tarafından üretilen dördüncü nesil Fairphone. Ekim 2021'de piyasaya sürülmüştür.
Phone call or receive problems!
Everytime, I make a phone call or received a phone call. There other side how call me is not able to hear my voices. Help to fix FairPhone 4. Do you think is the speaker part is the problem?
Update (05/13/23)
Resim
Which part?
Bu iyi bir soru mu?
Puan 1
1 Yorum
https://www.google.com/amp/s/amp.theguar...
Which part?
I try to put the image is not working well. So, put a link.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
No you have a problem in your Microphone, you should replace it.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
The speaker and microphone are the same part or component?
tarafından Paylaş
Yorum Ekle
En Yararlı Yanıt
Hi @erickonix,
Can you be heard OK when using the phone in loudspeaker mode when on a call?
Is the phone in a protective case at all? If so remove from the case and check if it now works OK.
Try using a vacuum cleaner to clear the voice inlet hole located on the bottom edge of the phone in case it is blocked with lint etc, and check.
If still no good it may be the microphone in the phone.
Puan 3
15 Yorum:
Even with or without the phone case still same problem. Where is located the microphone?
tarafından Paylaş
@erickonix
Did you try clearing the voice inlet hole using a vacuum cleaner, you didn't say?
tarafından Paylaş
Can you show me as pictures where is located?
tarafından Paylaş
@erickonix
Can't find any pictures but there are two small holes on the bottom edge of the phone for the microphone.
Do not stick a pin in them to see if they're clear as you may damage it
There's also a small hole at the top for another microphone which is used for loudspeaker calls
tarafından Paylaş
In bottom part of FairPhone 4. In the center bottom is USB type C. At the right side of USB type C have 3 holes. At the left side is have small hole. So, which part is the microphone?
tarafından Paylaş
10 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
erickonix sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 116
Her zaman: 2,152
