Ana içeriğe geç
Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
100 Soru Tümünü görüntüle
MacBook battery dead after only 18 cycles
Got this laptop from a friend, he says I can keep it if I can figure out how to fix it. The laptop is basically brand new, and the system information shows that it has only had 18 battery cycles. The MacBook will not turn on without being plugged into an outlet. The battery will not charge and has a "service recommended" alert. I have tried resetting the SMC but it doesn't seem to have worked. The MacBook is also ridiculously slow, taking as much as 5 minutes just to load the desktop, and often taking several minutes to open any apps. Despite this, the fans are constantly running at full blast, even though the MacBook is at room temperature. I was thinking of just replacing the battery, but I don't want to replace it just for the laptop to this slow.
Is there something else I should try, or should I just replace the battery?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Let’s get a better view of things. Install this gem of an App CoconutBattery take a snapshot of the main apps window and port it here so we can see things.
Bu yanıt yardımcı oldu mu?
Puan 0
10 Yorum:
Will do, I'll post it once its done installing.
tarafından
Heres what it says:
Current Charge: 0 mAh
Full Charge Capacity: 4381 mAh
0%
Design Capacity: 4381 mAh
100%
Manufacture Date: 2019-11-25
Cycle Count: 18
macOS Battery Status: Poor
Battery Temperature: 24.5 C
Charging With: 0 Watts
Power Adapter: Connected
tarafından
@maximm66497 - Really need the other stuff. Can you post the snapshot please. Also what is the color of the MagSafe connector LED? Amber or Green.
tarafından
Where do I find the main apps window? I am using a 60 watt USB-C power adapter, which doesn't have any indicator lights.
tarafından
@maximm66497 - Sorry, no LEDs in yours its USB-C connected.
The apps window is the space it takes within the desktop. Think it like a real desktop where your papers and books are each is a window to knowledge! The simplest way is to use the Shift Command and 4 keys then capture the window.
Reference Take a screenshot on your Mac
Or just use a phone to take the picture
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Maxim M sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 137
