These tantalum caps are notorious for going bad on most generations of MacBook. The capacitor in question is C5800 and is a 33uF 16V in a T Case.
These ones at Mouser look to fit the bill, but you can probably also harvest them off other MacBook boards. Apple seems to love this style of Tantalum cap.
I will also mention, this will probably work just fine without the faulty cap, at least in the short term. If you can replace it safely and easily (which you should be able to in this case), absolutely do so. But it is likely worth it to test that it functions properly without the new capacitor on first so you know that's the extent of the problem before potentially introducing new factors when installing the new one.
I didn't see the other cap mentioned until I reread, but C5895 is a bit different, that's the one in the upper right that you circled in the post. That one is 150uF 6.3V in a B1S-1 case. These ones are a little funkier. But same theory applies. Can harvest off other boards if need be.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
1 Yorum
@oldturkey03 whoops! Just added thank you!
Andy tarafından
