Ana içeriğe geç
Aralık 2019'da piyasaya sürülen dördüncü nesil Mac Pro için onarım rehberleri ve söküm bilgileri.
Is it possible to replace the CPU socket on this board?
Hello! I have a late 2019 Mac Pro (like in the image above). It's an Intel Mac Pro that uses the Xeon Cascade Lake Series chipset (the W series).
Is it possible to replace the CPU socket on this board? If so, how difficult is it? If not, how expensive is it to just swap out the whole mobo? And is that difficult as well? Or is it better to just get it serviced?
Bu iyi bir soru mu?
Puan 2
1 Yorum
Basically, it is not recommended to replace, there is a great risk
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
This question has 2 answered depending on who you ask
Yes and no
Theoretically it can be replaced but this can only be done if you have very very very good microsoldering skills as it would require desoldering the whole socket from the board
The best thing to do it to replace the logicboard/motherboard if the damage is really bad
However if it’s just a couple bent pins you should be able to fix that if you have a steady hand…if your unsure about that I would take it to a repair specialist:-)
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 3
10 Yorum:
Gotcha, that definitely makes sense. I need a good enough magnifying glass to even see the %#*@ pins and what they're doing in the first place lol.
tarafından
@damusicman29
That’s it’s
Iv done it a couple times and it’s like trying to pick dust out if a carpet 😂😂😂
tarafından
@hellomacos haha exactly; luckily, the little snag on the pins isn't too insane, I just need to be able to look at what's going on, though I might be able to fix it
tarafından
@damusicman29
If it helps I can tell you the best way of getting those pins unbent
If you want to do that if you can use this guide to upload some photos of the socket that would be great
Mevcut bir soruya görsel ekleme
tarafından
TY! I'm unfortunately having a tough time taking photos; even with lots of light, it's hard to see which ones are bent. Though, I just spent 2 hours VERY slowly barely touching the couple pins that were bent. I have a little electronics repair kit and I just use the smallest plastic point to push it softly in one direction until it kinda gave me some give, if that makes sense.
When I walk around it, I can see the light hitting the pins at different angles, which makes it look like it's still bent, but idk if that's just because it IS bent a little in the middle of the pin (because I had to bend it back) or if it's fine and it's just my illusion. It is seriously hard to see. I even bought a 8X magnifying headset w/a bright LED on it. It works-ish; I know there's better ones out there. Part of the issue is that I have to bend down (and the Mac Pro is on my counter, but it's still a pain to get to with the frame).
Anyway, I fired it up and it works, haha. To be sure, I also cleaned my RAM sticks beforehand.
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
damusicman29 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,127
