The machine starts then stops and switches off…
The panel has all the lights working, I switch it on it works for a few mins the switches off all together.
Bu iyi bir soru mu?
Puan
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 108
@georgeg66301 Can you open the dryer up and upload a picture of the control board?
Andrew S tarafından
Here's a thought. If the laundry knocks the door slightly ajar, it might be enough for the door switch to sense this and stop the dryer. Depending the on switch, this can happen even when the door opens only a millimeter or two. A simple test would be to hold the door closed manually and see if the dryer runs any longer. Other than that, it could be any number of sensors that detect something not quite right - electronics can be tricky to troubleshoot if you don't know what the computer is looking for. Finding that fault likely will take a technician. Good luck.
Klaus Martinek tarafından
@georgeg66301 let's first verify that your dryer is a Miele Softtronic T 8403 C.
oldturkey03 tarafından
T8422C is the actual model number but that wasn’t on the list when I first posted.
George G tarafından
@andrewsawesome it won’t let me upload photos.
George G tarafından
1 tane daha yorum göster
