Ana içeriğe geç
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
113 Soru Tümünü görüntüle
Brightness not working on control panel or keyboard?
My Mac is a relatively new 2020 model. I got it second-hand in 2022. I've never had an issue with it other than it being sort of slow- crazy right?? I'm pretty sure it's just slow cause I have a lot of EPUB files and book files on there but I'm not gonna get into that. Recently -by that I mean 5 minutes ago- I opened my Mac while I had a light on in my bedroom. Now, it's currently 1 am so it's dark outside. I couldn't really see my screen as well as I usually did and checked my brightness. It was at 100% already so I turned my light off to see it better. Now, I was curious as to why it seemed so dim so I was messing around with the brightness on the small interactive display on the top of my keyboard and it wasn't changing the brightness at all. Sure, the bar was moving but there was no difference in the display. I even went up to my control centre on my Mac to mess around with the brightness that way and nothing changed; once again, the bar was moving yet there was no change at all. I haven't dropped it, been rough with it and it looks brand new like always- I haven't even touched it today other than to take it out of its case this morning while cleaning up. My Keyboard brightness works just fine it is just my Macbook display and I'm so confused. How do I fix this? What even is the issue here? I will attach some images of it at 100% brightness, 50% and 0% -which is usually where the Mac goes black- yet mine stays on the same brightness.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This seems like it might be a software glitch. Have you tried rebooting it? You could also try doing an SMC reset and a NVRAM reset. You could also try booting into Safe Mode. If the issue isn't resolved after taking those steps, you may have a hardware issue, which would require more advanced troubleshooting to diagnose. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
John Mayonnad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 42
