Ana içeriğe geç
This device is a Non-Contact Voltage Tester Pen, with acceptable range from 50 to 1000V AC.
New Klein NCVT1P no test sound
My new Klein NCVT1P responds correctly to turning on and off with lights and beeps but makes no sound when testing a known good circuit.(the red led illuminates but no sound) Is there a switch to change it from silent to audible notification of voltage?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @timmcintyre
According to the user guide there is a silent mode
"The tester can be operated with only visual indication of voltage. With the tester powered off, press and hold the power button (4) until the green LED (2) illuminates, then release."
If it is disabled then perhaps performing the same procedure will enable it, it doesn't say.
If not, return it for a replacement or a refund
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Turn the tester on by pushing the button and immediately releasing it. Don’t wait for the audible beep as happens when you hold the button to turn it on. Simply press and release
Puan 0
2 Yorum:
i’m having the same issue you’re supposed to hold down the ncv for two seconds but mine still isn’t audible
tarafından
For sound mode you have to press the power button for a brief second then release. Check out my video above.
tarafından
Yorum Ekle
Yanıtını ekle
Tim McIntyre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 14
Son 30 gün: 82
Her zaman: 2,023
