Ana içeriğe geç
Release February 2011, identified by model number ELPH 300 HS - BD.
My camera was left in the garage during the winter
My camera was left in the garage during the winter. How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
What is wrong with it? Does it not power on?
tarafından
@cwi no, it's not turning on.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@bellz55147 the very first thing you want to do is to replace the battery. Your battery most likely will not have survived the winter cold (not sure how cold your winters get ;-) or is discharged below it's charging threshold. Once you replace the battery, try and see if it power on. If it does not, you will have to disassemble your camera and inspect the circuit board. It is possible that you have corrosion on it from frost and condensation. Use these guides Canon PowerShot ELPH 300 HS to work on your camera.
It may help if you post some good pictures of your circuit board with your question. that way we can see what you see and hopefully provide you with additional guidance.
Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
bellz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 69
