Ana içeriğe geç
The Dell Latitude E7470 is marketed as an ultraportable business laptop that is part of Latitude’s Exx70 model line. The E7470 model was released in April 2016.
laptop wont turn on after a spark in battery connector
My laptop battery died so I got a new one. I removed the old battery, i plugged in the new one and tested it. The laptop turned on, everything was working fine. While I was putting the screws on the battery, my screwdriver touched the connector which connects the battery and the motherboard, and it produced a little spark. So now my laptop is not turning on. When I connected the charger it got turned on and boots properly. But it doesn't work without the charger.
Please help me
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Any spark in the laptop can damage hardware components. Without checking, no one can say what the fault is.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@erenyeager72921 "But it doesn't work without the charger." sounds like your accidental touch caused a shortening of the battery circuitry. That is why your computer does not run on battery power. You will have to determine what got shorted out. Take some GOOD pictures of your motherboard and in particular the area where you worked on. Let's see if we can find some bad components. This repair will most like require board level soldering etc. so it'll be not the easiest of all fixes.
Try this too. Disconnect the battery cable from the motherboard and leave it off for a while couple of hours. Remove the AC power from your laptop and press the power button down and hold for about a minute. Then reconnect power and see if that made a difference.
Adding images to an existing question
Puan 0
Yorum Ekle
A short circuit may have burned out.
Puan 0
Yorum Ekle
Yanıtını ekle
Eren Yeager sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 67
Her zaman: 2,017
