Hi @gregoryvenezia
I think that the make and model number of your motherboard is Compal LA-B111p. This information should be printed on the motherboard somewhere.
If this is correct then the faulty component (designated PL701 on the board) is an inductor, part number HCB2012KF-121T50_0805.
The HCB2012KF-121T50 is the part number and the 0805 is the smd package size of the component
If you search online using the part number only, you will find suppliers but most only supply in multiples of 50 units or more.
Hi @gregoryvenezia
Just to verify that it is the designated PL701component, here's an image from the schematic.
Use an Ohmmeter to check for continuity from PU701 pin 8 to one side of PL 701, as can be seen on the schematic (arrowed)
If it isn't then, as a lot of the components around PU701 aren't designated, you may have to find out which component it is by using the schematic
Try checking for continuity from each of the pins on PU701 and see which pin connects to the pad where the burnt out component was (is?)
(click on image)
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
4
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
