Ana içeriğe geç
Dördüncü nesil iPad Pro 12.9" için onarım ve söküm bilgileri. Mart 2020'de duyuruldu ve piyasaya sürüldü. Model A2229.
Ipad 4th Gen ISSUE
I have a ipad 4th gen and when using the screenflashes purple quickly and restarts. this is happening all the time now and cat really use it. any ideas how to fix without taking it to apple for an extremly high fix price and no i dont have a warranty.
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You may not have Apple Care+ but if the device is not damaged, you have a manufacturer’s warranty for a year from original purchase date. Since the 10th gen didn’t even come out until October of last year, you should still be well within this. You can check at Apple’s Coverage Checker with your serial number.
(I just noticed your post says 4th gen, in which case, no you would be well out of warranty).
Otherwise, for some ideas of what might be causing the issue, I would check to see if you have any panic logs that were generated from the crashes.
In your Settings, navigate to Privacy > Analytics & Improvements > Analytics Data. Skim through this list for any files with the name panic.full in the title. If you find any with recent dates, add a screenshot, or copy the first page or so of the log’s text into your question.
UPDATE 06/21/2023 - Based on the panic you gave, I found this post in another forum, which seems to point to a similar issue occurring in some versions of iOS 15. It’s possible this is a software issue. The panic is actually pretty vague–“Kernel data abort.”
But I suspect in your case it may be hardware related. It’s hard to know for sure. This particular panic also calls out fitcored as the panicked task. Which relates to fitness/health functions. There is also specific mention of Apple USB Audio Device Driver. Which may not mean much depending on the underlying cause. But could be relevant if there are other panics which mention the same things.
Digging into some of my resources, I found mentions of CPU or CPU power. Which could make sense based on these symptoms. I am always skeptical of these sort of bulk lists on unvetted solutions with no explanation or reasoning. But it’s better than nothing. On 12.9” models I always worry about bend, which can cause board issues.
I would try a software restore first. Or DFU even honestly. I would normally put in links fo directions on those, but I have already been nursing this answer too long and I want to get it posted. Seeing more panics might also help, in the case that they aren’t all the same.
Bu yanıt yardımcı oldu mu?
Puan 2
11 Yorum:
there is one that has panic full in there.
tarafından
not sure how to add pic of ot tho?
tarafından
@choose35196 go to options and edit, above where you write there is a toolbar over next the right there is a box shape image beside a curve arrow, thats for images
tarafından
Ok, it done now.
tarafından
Can you see the picture i uploaded.
tarafından
6 tane daha yorum göster
Yorum Ekle
Görsel içeriğini görün:
Resim
Resim
Resim
Resim
Resim
Puan 0
1 Yorum:
Can someone look at this and help? iPad Pro 12.9 (4th Gen). Apps keep crashing and iPad gets stuck in a reboot loop. I have to use my Macbook to either restore the iPad to factory settings, or update its software.
tarafından
Yorum Ekle
Yanıtını ekle
choose sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 20
Son 30 gün: 48
Her zaman: 616
