Ana içeriğe geç
The Pearl Abrasive Cement Saw model VX141MSPROWR is a paver and block saw designed to cut up to 8" x 8" x 16" cinder blocks, bricks, blocks, pavers, terra cotta, stone, and roofing tile.
2 Soru Tümünü görüntüle
Anyone have tips for installing the blade? It doesn’t seem to fit
The hole in the center of the blade doesn’t seem to fit the the diameter of the blade shaft in the saw.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@joshuah12941 we do not know what blade you have. and I assume your blade is to small to fit the arbor. Your Pearl VX141MSPROWR has a 1" in ch arbor. So, your replacement blade will have to have a 1" hole to fit on that arbor. Check the parts manual on here Pearl Abrasive Cement Saw VX141MSPROWR (2014) for more info
Let us know what blade you got. You can always post images with your Question which makes it easy for us to see what you see
Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Joshua H sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 21
