iPhone SE 2020 having issues after battery replacement
Recently replaced the battery on my iPhone SE 2020. After I finished the battery replacement, the phone wouldn’t turn on. I plugged it in and it booted, but the power button no longer worked. I ended up replacing the power button cable connector and it started working, but the logic board, where the A13 chip is located, started heating up like crazy and the phone shut off due to high temperature. I carefully disassembled and reassembled the whole phone, which seemed to have fixed the issue. Then, the rear camera stopped focusing. I had an iPhone 8 camera module lying around so I swapped it in and it still wouldn’t focus. I decided to clean out the inside of the camera lens with rubbing alcohol and try again. After that, the camera started working properly . I resealed the phone with a Display Adhesive, and when I turned it back on, the camera couldn’t focus again. I thought it might have been a software issue, so I decided to do a factory reset on the phone. After the phone was reset, I tried to set it up again, but it would give a “unable to activate” alert. I then connected it to a mac and tried to activate it, and the mac also said it was unable to activate (see photos). Is there anything else I could do?
Bu iyi bir soru mu?
2 Yorum
Can you check to see if the device is able to report its IMEI number? As in, it shows up in settings? If it says "N/A" next to IMEI it might have a board problem.
Jesse Hooton tarafından
I can’t check in settings since it won’t activate, but in the the “hello” screen of the phone when I click then “i” in the bottom right corner it doesn’t give an imei, when it normally does
Maxim M tarafından
