Ana içeriğe geç
2014 yılında tanıtılan, otomatik buz yapıcısı ve kompakt tasarımıyla öne çıkan, alt donduruculu ve French Door buzdolabı stiline sahip Samsung RF20HFENB** buzdolabı için onarım ve ek bilgiler. Bu sayfa, RF20HFENB** modeliyle eşleşen model numaralarına yönelik bilgileri içermektedir.
Samsung model RF20HFENBBC
I have a water pooling problem under the fruit and vegetable drawers on both sides of refrigerator. I clean it up and it just returns. Can anyone help? Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @patrick43472
Check if the drain tube (part #12 cabinet diagram) located in the drip tray below the evaporator unit which is behind a panel at the back of the refrigerator compartment is not blocked. (Access to the evaporator unit etc is through the door at the front by removing the panel at the back of the compartment).
This tube leads to an evaporator pan (part #14-2 cabinet diagram) located underneath the compartments.
When the refrigerator is in its defrost cycle, the meltwater from the defrosting accumulated ice build up on the evaporator unit, drips into a tray below the evaporator and then drains down to the evaporator pan and is evaporated naturally.
If it is blocked then the meltwater will back up and overflow into the refrigerator compartment.
There is also a similar drain tube below the evaporator unit inside the freezer compartment that does the same thing.
Try pouring a measured cup of water down the drain tube and check if all of it reaches the pan below the compartments.
Be safety aware disconnect the power to the refrigerator first
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Patrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 476
