Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Hard drive/Cable not working
So I've tried 2 cables, 2 hard drives and j can't seem to get the hard drives to spin up! Stuck on the flashing question mark and no startup keys are working at all, Looked for visible damage to connectors and motherboard components and there is none! Any help appreciated trying not to put any more money into it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Give this a read Mac startup key combinations
Are you sure you have a working keyboard? Try an external USB Mac keyboard to double check.
Can you give us some background on what happened. Did you have a liquid spill or dropped your system.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
I sadly only have windows keyboards, I have a wireless keyboard for Mac but that won't do me any good, I never dropped it or spilt liquid on it just stopped booting one day, Replaced the cable and replaced the new cable but none of it worked, Checked the drives on my working computer and they work just fine, No visible damage to the board or connector
tarafından
@xkienholz - The HDD SATA cable is a bit delicate! There are a few issues
1 - Some cables from third parties where not to spec!
2 - People tend to over crease the cable which damages the thin foil wires. I use an old BIC pen ink straw as a forming break. Making sure not to bend the cable beyond its radius.
3 - Case abrasion! I use a single strip of electricians tape where the cable rests.
Here’s a bit more Your Hard Drive Cable Is A Ticking Time Bomb
tarafından
@danj Well the cable is fine and working so, I didnt crease it and ive had electrical tape where the hard drive goes so I really dont know at this point, didnt know where to check voltages so I just put my positive and negative on different sides of the port and max volts I got was 4.45
tarafından
@xkienholz - OK forget the HDD cable for now... Lets go back to the Keyboard you need a USB keyboard and a Windows one will work! the key assignments are a bit different. Give this a quick read Using a Windows keyboard with a Mac done dive deeper unless you want more confusion as all we care about is these keys mapping for the Startup commands.
tarafından
Yorum Ekle
Yanıtını ekle
Xavier K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 60
