Ana içeriğe geç
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
Battery problems whenever I unplug the cord
Whenever i unplug the cord on my pavillion dv7 6b65dx
it turns off immediantly, because the battery isnt fully on for some reason. i have no idea what happened. maybe when my FATHER sat on it it broke off something
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@tristan31196 "sat on it it broke off something" sure it is a possibility. It is also another possibility that your battery is just no longer capable of holding a charge. The easiest way to determine that would be by attaching a USB ammeter and see if and how many amps your laptop tries to pull from the AC adapter while off.
Anyhow, check the charger for proper voltage output. Check the charging cable to ensure it does not show any bend, broken, or corroded pins, After that check the DC-in jack. Clean it out with a few drops of isopropyl alcohol and a few puffs of compressed air, something like air-in-a-can will work.
After that, chechange the battery and check the DC-in jack for proper voltage on the board side of the computer. See if that all works.
Download the Maintenance and service guide for your computer from here. It will help you to work on it.
Update (07/14/23)
@tristan31196 fell out where? Your DC-in jack? You can probably replace it. Post some pictures of the jack, or wherever the cable fell out of. Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It was able to work a couple of days ago for a few seconds without the cord, but it fell out, i think its a piece broke off
tarafından
Yorum Ekle
Yanıtını ekle
Tristan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 47
