Ana içeriğe geç
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
Swap logicboard and touch-ID with another MacBook same model
I have Two identical MacBook Air m1’s models. One is grey with broken screen, the other is space grey that is locked. Other than that all specs are the same, I.e. the base configuration.
I want to put the logicboard from the grey one with the busted screen into the space grey one that is locked, effectively making the space grey one not locked. Will that work considering Apple serialising and locking everything in all sort of ways.
Any help is appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
As you are swapping the logic boards with there power button (TouchID) that would work but why are you gonging Dow the hardier path? I would just swap out the displays as that would be the quicker and less risky path.
What can be confusing is a virgin display (brand new) wouldn’t work correctly as the displays firmware is not installed! That’s why you need the calibration tool, a used display in this series works! So in your case the working display.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mkkn Nkdl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 121
