What kind of screws?
Does anyone know what kind if screws the PAL uses? I stripped them opening it up and want to replace.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
They are most likely metric. Ace Hardware usually carries an assortment of metric screws. Take it in and see if you can find the right one.
Bu yanıt yardımcı oldu mu?
@julianboilen those look like #6 or #8 x3/4 rolling screws for plastics. You could measure the diameter and length with a pair of calipers or similar. #6 is 9/64" and #8 is 5/32" in diameter. Do not use wood screws from a hardware store since those are different. I am sure that the needed screws are readily available online.
Hi, did you find out which screw you needed for the Tivolio Ipal radio ? I am looking to get screws as I have misplaced those that hold in the back plate for the battery compartment.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 268
