Ana içeriğe geç
The Whirlpool WRS588FIHZ is a side-by-side stainless steel refrigerator with a total capacity of 21.7 cu. ft., featuring frameless glass shelves, LED lighting, adjustable gallon door bins, and a factory-installed ice maker. It is equipped with electronic temperature controls, temperature alarm, automatic defrost, and is ADA compliant.
What Makes a WHIRLPOOL Fridge Stop Working?
Compressor stopped working and not freezing on freezer side.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @eddiecorde16877
Are the lights still working in the refrigerator, you never said?
If not have you checked that the power outlet that the refrigerator is connected to is working OK?
If there is power connected to the refrigerator i.e. lights working, it may be a problem with the temp sensors in the refrigerator indicating that the set temp is OK (even when it's not) and therefore there's no need to have the compressor on.
It could also be a faulty control board or even a faulty compressor.
If the model is a Whirlpool WRS588FIHZ as selected by you, here's the tech sheet for the model, that will help.
Enter the service diagnostic mode as described in the sheet and check that the thermistors (both RC -refrigerator, and FC- freezer) and also the compressor are OK.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Eddie Cordero sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 447
