Ana içeriğe geç
How to replace keyboard surrounding plastic?
In life as a college student, laptops are not always the luckiest. I'm looking to replace the keyboard's surrounding plastic as it's badly cracked. I think it is called upper housing.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @bookworm3616
To replace the top cover, you have to completely disassemble the laptop.
Also getting just the top cover replacement part and not the complete top cover/keyboard assembly may be hard as it comes as one complete module.
Not totally sure re this model but with a lot of other HP models (different series) the keyboard is "riveted" to the top cover by nylon type plugs, so if you do find a top cover minus the keyboard, you may be able to remove the keyboard in your laptop by either snipping off the plugs or melting them with a soldering iron or similar and then gluing (epoxy?) your keyboard back into the new top cover
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.65 to find the part numbers for the various top cover/keyboards used in the model series and also the country specific suffixes required to amend the top cover/keyboard part number to suit your location.
Note that the top cover with keyboard information is at the very end of the Component Replacement Procedures i.e. complete disassembly.
Search online using the appropriate to your particular model variant top cover/keyboard part number only to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Bookworm 3616 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 361
