Ana içeriğe geç
Renkli ekrana, biraz daha fazla işlemci gücüne ve daha küçük bir kasaya sahip, 1998 yılında piyasaya sürülen güncellenmiş bir Nintendo Game Boy sürümüdür. Bu cihazın onarımı oldukça basittir.
What wire should I use for the speaker?
Hello! I have this game boy color with a messed up speaker and while trying to strip the wire I accidentally cut it, and it is way too short. I don’t have any wire the same size as this, but I have one that is smaller. Will this red wire work? It is about 1/2 to 1/3 the size.
Resim
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @nintendog909
If you have got enough red wire, run two red wires in parallel from the speaker to where they connect on the board. i.e. instead of one thick wire there will be two thin wires, but electrically they will be the same.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you! I got it to work!
tarafından
Yorum Ekle
Realistically as long as the wire type is good quality you're fine; you just need to make sure it fits without being crushed, basically.
Any reasonably thick wire will work since you're dealing with LV at most. If this were HV wiring it might matter.
Puan 0
Yorum Ekle
Yanıtını ekle
Bailey Bryan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 429
